christerljung said:
Could be a nice combo with this 18 tooth 15mm HTD:
http://www.ebay.com/itm/HTD-5mm-Pit...omation_Control_ET&hash=item3375624e81&_uhb=1
But i really like the #25 chain. Feels like the definite solution. Strong, reliable and quiet. This belt mod would still need the motorpulley file off.
Having the freewheel on the primary have been discussed a couple of pages back. There will be more force needed when pedaling because of rotating the jackshaft with its bearings and rubberseals, this resistance is multiplied by the secondary reduction(when pedaling).
btw One of the real benefits with this kit is that it let you pedal it with quite low resistance.
Christer- I think your reasoning is correct. The drive pulley has too small of a tooth count for good engagement. 14T is listed as "sub optimal" for 5mm pitch and "may cause skipping and accelerated belt wear". 16T is supposed to be adequate. 18T would be very positive but we'd lose a lot of reduction. Every tooth off of the driver is worth between 5 and 7 on the driven depending on it's size.
I've been following the discussion on moving the freewheel and I understand the reservations about pedaling drag. So far we've just been discussing it in theory. The sprocket is so inexpensive I'm tempted to try it and see how it actually feels. If it's acceptable it's a tempting mod because many freewheels up to the heavy duty White Bros freewheel can fit. It it turns out not to be good to have the freewheel on the primary side but I like the 120T sprocket, "a couple of zaps with the MIG welder and no more freewheel".
I'm just being stubborn about the belt drive. Since several people have solved for converting to chain primary I wouldn't be contributing anything by going the same route. If I can make the belt work (which is what I really want anyway) then people will have a choice which way to go. I think that for e-bikers who mostly ride on the street the belt is a better solution.
