bee
I 3d printed an adapter that adds some teeth to the existing pulley. It fits great, but I won't know if it's strong enough until I install it on a bike.
Another Pulley source for bigger 5mm-pitch belt units. Split type. http://www.cometkartsales.com/store/belts/5sprockets.htm
spinningmagnets said:Another Pulley source for bigger 5mm-pitch belt units. Split type. http://www.cometkartsales.com/store/belts/5sprockets.htm
I believe these use the Extron Karting interface of (BUT, I am not certain):
Extron sprocket 5-1/4" 5.25 133.35mm Bolt Circle Diameter (BCD), Six 5/16-inch mounting holes
Holy smoke! What material is that? Have you tried making a slip-on that fits the drive pulley? Can you cut these in teflon? This thing is giving my brain a snyapses attack!bee said:I 3d printed an adapter that adds some teeth to the existing pulley. It fits great, but I won't know if it's strong enough until I install it on a bike.
I can make one for LightingRods to try with a 20mm belt for the cost of shipping to see if it'll work.spinningmagnets said:Well done, sir! I think the big pulley will be more than fine with your 3D mod. It might not hold on the small pulley.
What would you charge for full retail price to a stranger to make one of these? I am certain that LightningRods will want one of these to test in a 20mm wide variation.
gestalt said:LightningRods said:I'm also looking into having one set of pulleys CNCed and then pulling a mold off of them. I can try 2 part industrial resin (like hard hat material) and see how that holds up. It pours into the mold like water and has a perfect finish. People make small boat propellors with the stuff.
How about having the part 3d printed and making a mold from that? Might be slightly less expensive.
bee said:I can make one for LightingRods to try with a 20mm belt for the cost of shipping to see if it'll work.
I don't have time to print more than a few, I'd prefer to just post the source/models for people to print up themselves. There are plenty of affordable 3d printing services, and you can generally use the 3d printer at your local hackerspace for free if you're up for learning a little bit about them.
For smaller stuff, shapeways might be affordable for strong steel pulleys: http://www.shapeways.com/materials/steel
I print the smaller pulley but there's no way that keyway will hold up on a plastic pulley, you'd need to cast it in metal.
LightningRods said:This gets the Thinking Outside of The Box award. If I had an applauding smiley, I'd use it. Kudos!
There was a guy selling brass powder resin cast pulleys for 3d printers, it was a gimmick for 3d printers where plastic parts are strong enough, but maybe it'd be strong enough for our GNG kits.gwhy! said:gestalt said:LightningRods said:I'm also looking into having one set of pulleys CNCed and then pulling a mold off of them. I can try 2 part industrial resin (like hard hat material) and see how that holds up. It pours into the mold like water and has a perfect finish. People make small boat propellors with the stuff.
ali powder mixed into the resin really works well for pulleys, I have done this and they do hold up ( only done 60t+ big pulleys ) . I didn't know this has been already discuss in this thread, sorry guys
LightningRods said:Bee, I'd love to see one of your 3D printed pulleys. I've had 3D objects printed at a number of different vendors. Some of it is flawless, some of it is kind of Lego-land. It would be good to have a smooth master to start with. For sure I will pay postage to get one to play with. Let's connect on that by PM.
One good solution for vinyl/resin pulleys is an aluminum or steel core that's embedded in the center. Then you bore the center hole and cut a keyway.
Something in my gut says that molded resin is going to work great for the drum of the pulley. My point again is that it's better to change out a $30 pulley and a $20 belt once a year rather than a $20 belt every week. Way less hassle and cheaper by far.
No one took any notice, when I posted it.... I even gave an approximate specification...crossbreak said:95T pulley, that should fit the GNG drive exactly : http://tncscooters.com/index.php?route=product/product&path=63_94&product_id=463
Miles said:No one took any notice, when I posted it.... I even gave an approximate specification...crossbreak said:95T pulley, that should fit the GNG drive exactly : http://tncscooters.com/index.php?route=product/product&path=63_94&product_id=463
I agree.LightningRods said:I think that the driver is most of the problem.
LightningRods said:Miles said:No one took any notice, when I posted it.... I even gave an approximate specification...crossbreak said:95T pulley, that should fit the GNG drive exactly : http://tncscooters.com/index.php?route=product/product&path=63_94&product_id=463
I noticed Miles. Thanks for taking the time to chase that down. I'd be interested to know whether virtually all of the GNGs problems come from the too small driver with sharp teeth or if the cheap cast driven pulley contributes. I think that the driver is most of the problem.
bzhwindtalker said:I doubled the phase wires and i'm tying the gng motor on 80 amps ATMcrossbreak said:seems like the GNG is good for at least 50amps. Noone ever tried that either.
I needed something to ride and was bored after exams so I hacked this together :
Mid range accel is brutal
80amps ?? wat voltagecrossbreak said:bzhwindtalker said:I doubled the phase wires and i'm tying the gng motor on 80 amps ATMcrossbreak said:seems like the GNG is good for at least 50amps. Noone ever tried that either.
Mid range accel is brutal![]()
WTF!!!!!!!!!
WTF!!!!!!!!!
WTF!!!!!!!!!
WTF!!!!!!!!!
WTF!!!!!!!!!
WTF!!!!!!!!!
WTF!!!!!!!!!
ok... someone who really thinks outside the GNG box! I would die to drive this one.... someday
guess this would suck dry my battery within.... seconds?
Are you in the 50mph+ club now?
