flat tire said:jjstripes said:I'm not sure what all the complaints are about.
Stock controller doesn't respond fast enough for racing where you are constantly on / off throttle and need instant response.
Do you have pictures of the destructed magnets? I managed to blow mine just now, motor was still touchable hot by hand. Stator in good shape. The motor couldn't startup properly even with stock controller so I don't know if it's a factory defect crack that got worse. I still don't quite understand how the middle of the magnet gave way with both sides clamped by the metal cap...
With the bac2000 it pulled and revved like a motherf*ker though :lol:
I wish cyc did a 25% wider rotor version to handle more power, same way we have cyclone 3kw and 4kw. Since the cyc can fit 68mm frame, pf92 frames and above could fit a wider motor easily.
