Uturn said:What would be advantages of the chain drive version? Less noise maybe, and what else?
Both motors do not look like they'd allow a double chainring setup.
neptronix said:Just FYI, Jon Chan told me that the price goes up after the initial run. He didn't specify how much.
neptronix said:Cross shop it with equivalent drives. Tangents.. aden power kit.. recumpence drive ( including the $$$ astro motor ).. etc.
You'll find it's very cheap at $700 and still kinda cheap at $1000.
neptronix said:Totally understand.
The reason i'm attracted to this is because you could fairly easily turn it into a direct wheel drive on the right frame.
neptronix said:The reason i'm attracted to this is because you could fairly easily turn it into a direct wheel drive on the right frame. The ultimate style of drive in my opinion.
Just my 2 cents.
Bike71 said:COMPARING X1 PRO NOISE WITH CYCLONE
https://web.facebook.com/CYCMOTORL...2y1UblZpup2FjOmi86TnCW9yHT_7osrnwLHYrFPZ0HXyV
neptronix said:Hey guys.. i was asking GNG if they had a 0.35mm lamination version of their mid drive motor..
And the guy at the end of the line told me about a new drive coming out in a few months.. the X1-pro.
Here are some pictures he sent:
Me: ( do you have a 0.35mm lam motor )
Them: Dear David,
Our new X1-pro 3000w motor is 0.2mm will be available in about 1-2 months but the thickness of GNG2016 premium motor stator lamination is 0.5mm.
Me: Wow, 0.2mm laminations!!! can you tell me more about this X1-pro?
Them: Yes! We spent a lot on the motor stator design and tooling. It is a 80OD motor.
Overall reduction 1:36.
Our motor is only 2.5kg with all the controller and reduction gear.
There will be two version, one with 2nd stage gear reduction, another with 2nd stage chain reduction. And there will also be different mounting option for 68/73/83/100/120mm bottom bracket.
So that's all the info i have for now, but i wanted to tip off ES...
endrew said:Bike71 said:COMPARING X1 PRO NOISE WITH CYCLONE
I think the video was removed. Mind summarize what it showed? Noise is my main concern regarding this motor...
