GoCycle
http://www.gocycle.com/v/vspfiles/assets/images/downloads/sn4pnt1_green_resetting_controller.pdf
Yep, you just hold the power button down for the appropriate time when the bike is on charge.
Actually I don't even think it needs to be on charge, you hold the brake, then press the red button until you hear the two beeps.
Kudos
Anyone know anything about the lithium battery upgrade that comes from the manufacturer?
I think the owner said he looked and it was about £500, more than that, no idea
Good to find a scrapper and build your own pack in the old casing
Kudos, thanks for info on USA mode, I'll get John to try it
I'd love to stuff some li cells in my stock battery case but I don't know what I would use for a BMS, I bet it would have to be tiny.
Ah yes, a BMS, not something I ever consider
I would just fit an external plug to monitor balance and balance manually as and when necessary, maybe try and squeeze some of the 2-4s HobbyKing LVC alarms in there as warning
What is the voltage and capacity of standard pack?
If you put in the cell-LVC alarms, be prepared to balance charge regularly, as they do (semi-slowly) imbalance a pack when left plugged in.
Its something like 28V. I know its 9Ah, round-cell, NiMH. For balancing we would have to replace the stock charging plug on the battery with some multi-pin plug. I don't know what the stock controller LVC is, probably easy to figure out.
Oh bugger, just bought 3 for my girlfriends bike. Not needed to balance the pack since I built the bike. Not even checked it in months. Guess they will go straight in the scrap parts / not used bin as soon as they arrive then. Thanks for the warning
Thread dig!!!
Anyone know if the gocycle will accept up to 29.4v? (7s Li-ion), or how I could tell by looking at the controller?
Luckily I have a 24v battery I can wire it up to and see if it runs... but before I do that can anyone tell by looking at it if it would suffer any damage with 29.4v? It has 35v caps.
I spent about 15min searching for a data sheet on this part to see if it will work at ~30V, but cant find one... I can't find this part anywhere. Anyone know where to find it?
This is what seems to be written on the part:
I[symbol?]R P744H
L8J6
[Serial number?]
I'm really interested in what you come up with here.
I've always liked the funky design of the gocycle but the one I tested for a while just didn't cut it power wise.
It you could up the voltage like you're trying or just replace the controller altogether it might actually make it usable.
Good luck...
Kudos
Hello there,
As a proud owner of a go-cycle myself I would like to perk some interest with all of you....
I am working on a crack to unlock the controller programming which will allow me to re-program the power setting/voltage/speed. My pioneer model has a USB interface in the front fork to link to PC. I think this is something for Gocycle to send updated control software to customers or something. I know the Gocycle is shipped to EU and USA customers and uses the same controller - only the programming is different to limit power to be legal in each country.
Thoughts?
Created a youtube video
BTW: The you tube test drive is me. It's hard to see but from the left to right I am going uphill. Fair to say 25 degree incline!
Hi
Im really interested in reprogramming the controller, the you tube video seems to have been removed
please advise
