d8veh said:
Maybe the S06P will be OK with the Q100H or 201 rpm Q100. The rotor in the Q100 rotates very fast, so you need a controller that can handle the high commutation speed, which many can't.
Those bottle battery integrated controllers are sealed, so you can't solder the shunt to get more current, plus, it's a pain to get all the connectors in the compartment, so IMHO, it's better to get a separate controller and stick it in a box somewhere.
Yeah, realize I'm not getting the most out of the controller by picking this battery pack, and the battery cells are not all that. But I'm in a recovery process and can't wait to get on my bike again, so I just wanna have an easy solution that can be installed quickly, while it's still summer. No patience for DIYing battery/controller cases now. I might regret not being able to get to the shunt, but at least it will be good for range
Under normal circumstances I've got no problem DIYing, been etching PCBs, building headphone amps, etc. But I haven't got the energy for it atm.
mlt34 said:
technically slower rpm motors are always better at hills, since they will stay in a more efficient speed and lose less energy as waste heat. They'll also keep your controller happier and cooler. And you'll get better overall range.
All those advantages come at the cost of speed though.
Maybe getting the 201rpm won't be that bad, I'd rather go 15mph everywhere than dropping below 15mph uphill.
silentflight said:
Looks like I'm too late to this thread. You mentioned that a local dealer sells Bionx kits, were you able to test ride one? There is a world of difference between torque sensing and cadence sensing pedal assist- speaking from firsthand experience and many miles on each in all types of terrain. You own three nice bikes, so it seems fairly likely that you enjoy biking/pedaling and simply want some extra power to fight the hills and wind and go farther. Your first post is almost a perfect case for a Bionx system. Cadence sensing is clunky and doesn't feel natural, torque sensing works like a bike should in all conditions, no throttle because bikes have always had a "pedal harder to get more power" interface you won't miss a throttle at all if you enjoy riding normal bikes and aren't looking for an electric moped/motorcycle type of ride.
They are somewhat flexible, you can use any battery you like, and of any size (regen may not work, but that is not very useful anyway) and you can remove the speed limit as well on either the old I2C or newer canbus models using a tool discussed on the german pedelec forum and sold by one of the members there.
If you enjoy DIY projects, then going with a Thun sensor and a Cycle Analyst is also a good choice.
There are some torque sensing mid-drive bikes which you might enjoy trying, the Trek Superfly and Haibike models with the Bosch motor are available in Europe. Even if you aren't interested in buying one a test ride would be fun and educational.
Bottom line is that trying some bikes is a good way for people new to electric bikes to find what is best for them. The advice here at the sphere can be very useful, but it doesn't replace getting on a few bikes and seeing for yourself how they perform.
A used Bionx kit would likely be perfect for you, at least until a solid-performing torque-sensing mid-drive kit is available. The new BIonx kits are somewhat expensive, but when you compare the quality and reliability with other options it is evident why they sell fairly well. I think a torque sensing mid-drive would be even better, but I haven't ridden one yet myself.
Not sure the Norwegian BionX dealer is still around, but I found the price for the 250W24V kit, it was ~$2700 incl vat. I can get an electric Haibike (I belive it was) for about that ammount.
My experience with ebikes is limited to test riding the sad looking
Flyer T5 Deluxe http://ginnersport.com/shop/e-bikes/flyer-t-5-deluxe-elektrofahrrad/
I could live with that speed and power since I haven't tried a faster bike
The torque sensor was functioning very well, and I fear the lack of this sensor would be a bigger problem than the lack of power/speed.
But the order is placed at BSMb, and the price suits me fine. So I'm trying to make the best out of that, and ensure that I get everything I need on first attempt. Thun and Cycle Analyst could be the next step.
