rick_p
I picked up this older controller and I think it has never been used. I tested it with a 48 volt battery and throttle and it worked but I have a few questions because the documentation I have found online is been pretty thin. I'm hoping someone has some experience with these. It appears there are a few model numbers for more or less the same controller but I'm not sure if there are differences between them. This one is an MX25 V2.0 -L
![MX25-V2.0.jpg MX25-V2.0.jpg](https://endless-sphere.com/sphere/data/attachments/196/196074-dbddd640879413755dcc4ce209c9c4ec.jpg)
Questions:
1. It has a PAS connector but I wasn't able to find any information about it. There isn't a connector for a display, so how does the PAS work? Does it only support one level or something?
2. The documentation I found says "you can force it to use lower voltages like 48v, 36v, and 24v". What does that mean exactly? Does it mean that by default it is set to 72 volt? I tested it briefly with a 48 volt battery and it seemed to work nicely and throttle smoothly with no load, but I decided to wait for an answer to this question before riding it under load in case it needs to be programmed for 48 volt, I don't want to damage my wheel or battery.
3. Speaking of programming, I don't see a port for that on the controller, and from the posts I found about this controller on the Golden Motor website, it requires a special (expensive) cable and probably not worth pursuing.
Any and all guidance is greatly appreciated.
Questions:
