Good bikes with belt drive and IGH for Bafang conversion?
jdash
100 µW
What would be good bikes for Bafang (or eRad) 750W conversion that have belt drive and internal gear hub? I looked around but it was hard to find right ones or to tell whether they are compatible with Bafang or not. I like the belt drive because it is really clean. For IGH, I prefer NuVinci, but others will be fine too.
In general, your best bet would be to post a bike you are interested in and ask if that is a good candidate.
Belt drive: the problem here is that the BBS02 has a unique front chainring mount and I am not aware of any compatible belt drive pulleys. Let me know if you find one.
Any bike that satisfies these two requirements will likely be a good candidate. A steel frame is a plus since it is stronger.
Battery: you will need to make sure the battery you want to use will fit. I prefer using the "dolphin" frame mounted type which typically only fits medium non-FS frames and a limited number of FS frames.
Bottom bracket: must be threaded 68mm or 73mm (longer mounting screws and some washers necessary). You might be able to convert a BB30 to fit - I haven't done this but have seen adapters.
also, consider having at least front, if not FS - you will realize how nice it is (the need for it) going 30 mph.
