Reid Welch
I'd buy this in a heartbeat if I needed another e-bike.
Shipping is included. $339
The stickers all peel off at will.
http://www.thesuperkids.com/20cue.html
It's got a simple, brushed gear reduction (Unite MY1018) motor driving the rear wheel through rugged, simple chain drive.
This general system, which I have in my own Currie Mongoose Cruiser, pedals as easily as any non-electric.
The motor drive freewheels at the hub so there's absolutely no degradation of pedal-ability.
It's the simplest, strongest, application of a side-drive motor to a bike.
The Unite motor costs $45 (from TNC Scooters) to replace if it breaks;
and it runs without groans or shudders from a simple cool-running controller, $40 to replace if it breaks.
This general system (non hub motor) has the advantage of allowing for a bulletproof bike wheel.
The hubs too are steel if they are like my bike's hubs.
No spoke breakages with this bike.
Whereas, my retro-bike is a hardtail with primitive front springer fork,
here you've got front and rear suspension, all in steel for strength.
You can put a better battery (NiMH) into that admittedly ugly box, for double the range.
You can paint that box a better color if you want. Note the easy reach to the power off-on switch--right there on the battery box.
You can enjoy this bike as-is, and upgrade the battery or even hot-rod the motor later on for 24-25mph level road operation.
It won't be a grade-A quality bike, but it's going to be rugged, strong and capable of jumping the rough stuff.
Set it up right and keep it clean and it will last forever.
Check it out? What do you think. I think it's almost a steel steal.
That electric blue color lights up in sunlight like nothing else.
My own electric blue Mongoose cruiser draws color-compliments all the time.
This is an all-steel bike; unless you must haul it upstairs you want an all-steel bike for rugged e-biking.
With its pedal-gearing you can go mountain biking.
The twenty pounds of lead will not add to the fun when you drain them, though.
The limitation is, the e-drive gearing is fixed, as is also true with all but Cyclone-type e-bikes and the neat, two-speed Crystalyte hub motors.
You can use this torquey e-drive for assist on grades
but not very battery-efficiently--unless you help it on those grades.
It will go 16 to 17mph on the level road. With 36V (the controller will take it), it'll go about 24mph.
It has plenty of torque to start you up at stoplights without pedaling;
that's the benefit offered by any gear motor.
If used as a city bike, put slick tread balloon tires on the thing;
knobby tires are poor for an ebike, and of no benefit on pavement;
only a detriment against rolling ease, handling and wet road-grip.
--the Bontrager Hank (2.25" wide) or Big Hank (2.5" wide) balloon slick is my personal tire choice for added comfort and great grip to wet or dry pavement, and for silent running and low rolling resistance.
I should be a bike salesman. Someone send me a commission check,
please?
:lol: :lol: :lol:
please?
:lol: :lol: :lol:
