Success! My previous post on the 6fet greentime controller about which wires to connect to get 24v/36v or 48v.
I'll post the pic again below:
[img
][/img]
connection 2: gives 24v lvc
connection 3: gives 36v lvc
connection 1: is not 24v or 36v, not supposed to be connected that way, but it might give a different lvc, haven't tested to see if it gives a higher lvc.
default lvc with no connections is 48v
One note: the large resistor that drops voltage to circuit board is for 48v default, should change that resistor to suit new lvc.
The unused hole in pic above might also be useful if going for higher voltages
regarding running this controller with cyclone geared motor: it works very very nicely as sensorless controller, meaning its easy to bypass cyclone internal controller,
can remove cyclone controller and just run off the three thick phase wires.
The other very nice thing about this controller is in sensorless mode it will start the motor from zero rpm. Means no issues with freewheel on cyclone motors.
Its looking like the 6fet are very good controllers. I ran a 24v 180watt cyclone motor on 48v to max rpm, no hickups in sensorless mode at high rpm.
Have to disagree with Ian Mich whose advice was not to buy these. Looks good to me!
