a pair of them run your big motor? i thought you could only use 1 controller per motor.John in CR said:I like both. My problem with the 18's is no regen braking. The plug braking it has works if you only use it intermittently, but it turns all that braking force into heat in the motor and controller. I wish we could figure out how to make that regen instead of plug braking, because a pair of them run my big motor quite nicely pushing 100A through each. 15kw peak input into a high efficiency motor geared for 65mph top speed make for some real get up and go even with my 170-180kg all up load. My 65kg buddy begged and begged for a ride the other day, and though he never got to WOT and managed to stay in the saddle, he comes back with brown underwear saying I was irresponsible for letting him ride the beast. :lol: I told him wait till I finish modding my dual 24's and go to 150-200A peak...each![]()
I put a bug in Justin's ear the other day about adding anti-flip and wheelie control functions to the CA, and it just so happened he was already working to integrate and inclinometer for better pedal assist on hills. Plus he's already done a self balancing electric unicycle, so riding wheelies like a pro using a CA is a real possibility in 2013. 8) .
John
ooh wow i gotta move up to motorcycle hubs. are the 93% efficient hubs 6 phase?John in CR said:That's the old tech motors everyone is still using. The motors I use have 6 phase wires and 8 hall sensor wires and require either the expensive factory 6 phase controllers, or a pair of 3 phase controllers and my wiring instructions. Once you experience the smooth and silent power of 6 phases you'll never go back to 3, at least not without a sine wave controller.
Spicerack said:"Old Tech", I like it. Time you made your "new tech" public!
John, that bike sounds like a beast! Time for you to post up some photos/videos please!![]()
Happy New Year y'all for tonight! Only 12 hours away for us down under....let's kick '12 to the sidelines (because it's been a shit of a year) and welcome '13 in...
ian.mich said:ooh wow i gotta move up to motorcycle hubs. are the 93% efficient hubs 6 phase?
yes, checking it for low resistances between the combos will show a shorted fet.Lussy said:Thanks for the feedback guys,
Ian - I will check the resistance acrocss the power supply and phase wires? Will this show a shorted FET?
John - I never specified any current ramp up time. Can this be checked or adjusted?
Matt
Matt
whatever said:has anyone tried to flash a greentime/huatong/wuxi? controller using the xiecheng program?
