FINALLY!I'm DONE with ANDERSONS!
I've been running 4mm bullets from hobby king, the bear kind and the HTX covered ones and some of the castle creations solid versions. I still run Deans ultra's too. My setup is a mixture of both. 100amps peak for over 400 miles now and there is no sign of any wear on the connectors. I run the deans Ultra's through the wattmeter and key switch to the controller, and the 4mm bullets for the batteries and phase wires. Doesn't really matter, thats just what I have.
I use these on the phase wire to controller connections, use heatshrink tube over the non connecting area.
http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=67
I use these on the battery connections, with 10AWG wire, but the 10AWG wire is so big I had to press the connectors into the housings in reverse. I had to ad solder around the female diameter to make a ramp at the lip of the round. 12AWG works fine as normal.
http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9283
These are almost the same as the castle creations version, They look like a better solution then the normal bear HK 4mm bullets. Use a small flat head screw driver to slightly spread the pie shaped ends of the connector apart for a tighter hold.
http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11757
Castle creations 4mm bullets
http://www.google.com/#q=castle+creations+4mm&hl=en&prmd=ivs&source=univ&tbs=shop:1&tbo=u&ei=rHDdTPv2FsGBlAfstrTrDQ&sa=X&oi=product_result_group&ct=title&resnum=3&sqi=2&ved=0CCoQrQQwAg&fp=180c07a4ca199aa8
Deans ultra's can be found at pretty much any RC hobby store, but they are pricey. I have some slightly used ones here if you want to try a few I can mail you a few pairs. hehe. Really I like the Deans Ultra's the best, but they are not rated as high as the 4mm bullets. But Like I said I have had no problem with them at all.
Greg, you need to start using Flux when you solder if you don't already....
