flyinmonkie
deecanio said:im wondering if i can stick with the 3 speed shifter on the left and have it jump up a rear cluster instead, say 11/15/22 or something.
Dec,
You could measure the distance between your front chain rings, then pull you rear cassette apart. Pick the 3 sizes you want, and cut some pipe to make the spacing match the front chain rings. Then put only those three sprockets back on the rear cluster and use either more of the pipe or a single speed spacer kit to fill up the rest of the space on the hub. Then the front shifter should work. Not sure if it will work with a hub motor, unless it takes a cassette. If it takes a thread on freewheel, then that won't work. Just an idea. I might actualy try it on my bike as well, to do the same and put the shifter on the left side and limit the shifter to 3 clicks.
Another idea is to use a grip shift and just put it on the left side of the handle bar. It might turn the opposite way then it would, but should work.
Clay
