I just received two more headway 10ah 36v packs with bms and charger.The chargers that come with the latest pack puts out a little more voltage than the last one they sent with my old pack and finish charging at 43.9v.
What I am not to sure about is the little bms that came with each pack when the packs were charging the resistors down the bottom of the bms and the 12 little black components above them got quite hot .Not smoking hot but just hot to touch. My other big headway BMS on my old pack didn't get hot at all during charging.Is this ok?
The other thing is the 4 fets up the top of the bms two each side of the little aluminium block are (P75NF75) CCOUY 6 MAR 645 not sure if this is good or bad ?
I am not sure what the BMS is rated at my other one is 60A. perhaps this one is 30A not sure. I know the other big headway BMS I have can handle two p36v packs connected to make 72v. I hope this bms can can to?
My questions are a bit silly but I don't know much about the BMS.
Oh by the way, if anyone in Australia is looking for a headway pack I got them for $260 US or $399AU each with chargers and bms posted to my door from EV power Australia took a couple of days postage from WA and were packaged very well with lots of foam around the packs.
Kurt
edit. After feeling both Bms boards only one of them has the hot resistors the others are only warm and looking at both bms boards the resistors look a little different on each board. They have the same number 470 on them but the one on the left is the one that gets hot.The one on the right is now completely cold.From the little I know about a BMS I am guessing the left pack is more out of balance and the resistors are sorting this out and that's what the heat is?
I also gave one pack a load test with my 5304 48a controller . i could load the bms up to around 36A before it would cut out.I plan on using them on my wife's bike with a 25a controller so should be ok . I wouldn't mind running both packs together to make a 20ah pack just to give the battery's a easy life and hopefully last longer as they wont be discharged as deeply.
