bikeelectric
mrgarci1 said:OK so let me see if I understand - essentially, I can take these 2 pairs of wires and solder each pair together to make just one connection that will be used for both charging and discharging? That is, I can take the 2 reds, solder them together, put a red connector on, do the same thing with the 2 blacks, and charge and discharge thru the same place.
While I wish I had gotten the case I ordered in the bulk purchase, at least I can see where the wire go to on my battery pack ! Here is the picture of mine. I guess there is no way of knowing where yours go to. I haven't run my battery yet - only charged it. But since mine has a single wire labeled as charger I will use that only for charging and the other two wires for the load. I will share the positive wire for load and charging.
