A while back I bought a Metro w/no battery. I bought a used "B" battery and rode it for a couple of months. I wanted to get more speed and range so I bought a 48v 20 AH "Okoman" battery off eBay, mounted it on the book rack and wired it the "A" position of the switch thinking I would get more speed and distance. Since doing this I've ridden the bike about 15-20 times with no issues however the speed and range was no greater than with the 36v 13AH factory battery which I've since sold. First time ridding it in three days, it was fine that last time I used it. Yesterday I started off, all seemed perfectly normal and then in about 15' of movement it just stopped. I released and twisted the throttle again, the motor acted like it wanted to turn but there was a stick thru the spokes so to speak, the motor made a bit of a clunk sound, I could feel the torque of it wanting to spin but it didn't. I turned it on and off, pulled and released the brakes but nothing changed. Checking things over for a loose connections or something else wrong and after a couple more tries the battery lights failed to come on and twisting the throttle no longer did anything. Today I've used a MM, the brake switches are working fine. The battery reads 54v. I moved the battery connector to the "B" position on the switch module, nothing changed, the fuse on the switch module is good. I measured voltage at the chain stay motor connector, its also 54v there.
Anyone have any ideas what could have happened? Did I burn up the motor or the controller? How would I test for this?
