Beagle123
I just bought this controller:
http://www.tncscooters.com/LB37.php
I hooked-up the motor to the yellow/blue wires. I hooked-up the throttle to the blue/black/red plug wires. Then, when I hooked up the battery, the motor went full throttle, leaped off the table, bent the axle of my CVT transmission, and landed in a pile while luckily unplugging itself in the crash.
I brushed myself off, and tried again. I disconnected the "lock" connection. This is essentially an on/off switch. So I turned the controller off. Then I disconnected the throttle completely. This was labeled as "deraileur." The motor was already disconnected. So nothing was connected. When I connected the battery again, I tested the motor plug, and it showed that exactly 52 volts were across the motor connection. This seems like a short circuit of some sort. My other controller (36v) will show a max of 25 volts to the motor. I would expect this controller to show a max voltage of maybe 40 volts to the motor at full throttle. It seems like it should never blast the full voltage.
What did I do wrong?
Here are my thoughts:
I correctly connected the motor to the yellow/blue plug as in the wiring diagram, and the motor is reversable, so it can't be backwaards. I think that eliminates the motor connection as the cause of the problem.
I connected the battery wires correctly too. They were the big red and black wires. Red to red, black to black. That shouldn't be a problem.
When I connected the throttle it looked very straight-forward-- I connected black to black, blue to blue, and red to brown (similar). However, I didn't verify that these connections were correct using my voltmeter.
So it is possible that I had the motor wired to full throttle when I connected the battery the first time. That blast of power could have damaged the controller (?). I tend to think not because wiring it incorectly, would just make the controller be at full throttle, which is a normal condition. It should survive that.
I think its correct to assume that the controller is broken if you connect the battery to it with everything else disconnected, and the motor connection shows 52v (exact voltage of battery).
Fetcher, are you out there?
