bigedgar said:Well shoot, I had no idea caps had a positive and negative
Not all of them do! But all of them that matter to us, do.
amberwolf said:The hole in the case thing only works easily if the top comes off the case, not if the board has to slide into it from the end.
If it goes in from the end, you'd need a long slot as wide as the caps.![]()
John in CR said:A relatively cheap solution if you can find one is a Kelly KDS48050E 24-48V 50A programmable controller, and be sure to get the programming cord if you can't make one up yourself, or already have what's needed.
If you want to go the ultra-cheap route that requires some learning about electronics, and you are willing to put the effort into tuning it to your system, you could DIY a controller using something like this as your base https://www.amazon.com/Controller-1...=psdc_306530011_t1_B07D31MGFF#customerReviews
bigedgar said:And the bare controller board is yet another option that I'd love to have in my quiver, so to speak, I'll keep that in mind. Thank you.
An ebrake is not useful for brushed controller WOT failure, because the FETs are actually shorted, making an effectively-direct connection between motor and batteries.John in CR said:and for safety an Ebrake cutoff too, especially since brushed motor controllers can fail in WOT (Wide Open Throttle) state.
That usually means the FETs are blown, shorted on, for a brushed motor. Or it can simply mean the ground wire to the throttle is broken.bigedgar said:The bad news, however, is that I seem to have lost throttle control. What I mean by that is that as soon as I connect the controller to the battery, motor, throttle control, etc., the motor kicks on full-bore. What happened with my pre-modded controller is that I connect everything up, and the motor doesn't spin until I a) turn the power button on the throttle control to "on", and b) turn the throttle.
I can't see the image because the external site is blocking me, but if you upload it to the forum with teh attachements tab then anyone that can see the post can see the pic.You can see in the gif below that as soon as I complete the circuit by turning on the switch, the motor kicks on full throttle.
https://imgur.com/a/6OdBair
There is no reason that replacing the caps would cause this. Even if they were connected backwards, all that would happen is they would explode shortly after power was connected, if the fuse didn't blow first.replaced the caps on two separate controllers and both had the same result (full throttle once all connections were made). My guess is that something is wrong with my modded controllers. One of the modded controllers was effectively brand new, the other was one that had already blown the prior set of caps (and perhaps sustained some damage to the mosfets in the process).
It is not tape. It is solder, over the entire surface of the PCB traces. It's common in cheaper controllers to do this to "thicken" the traces to carry more current than they could with just the bare copper. (better controllers use busbars or thicker copper traces, etc., to do this job).there's some kind of foil tape over all the solder joints.
While that is possible, it isn't very likely taht it would cause full throtlte operation--it would more likely prevent it form working at all. If there were a short big enough to cause full throttle operation, you'd see it across the wide soldered traces (the ones that look taped), shorting between them, either on this side of the board or the other.I may have unintentionally heated some solder for a different component and caused a short.
bigedgar said:I don't like the fact that I can't see where things are connected :x
As noted before, it's probably not a short, but rather an open circuit, broken wire or pushed out contact, etc. This can happen from plugging and unplugging stuff, which you've had to do a fair bit with this system.I considered that I might have a short in the throttle wiring, but I haven't touched the throttle except to connect the tamiya connector to the controller to test out my modded controllers, so I thought it was unlikely that it was the cause of the problem.
Yes, because it is *not* tape.bigedgar said:Ah, so everything under one of those "tape" sections is effectively connected together?
This is the most liekly thing..but if it's a contact that is backing out of the ocnnector as you plug it in, on either the throttle *or* the controller side, you could still see this result.I connected everything up to a stock, unmodified controller today and everything works as expected. I assume from this that the throttle wiring is all intact and there is something wrong with the controller.
It's unlikely that you could've damaged the FETs durign this process, unless the entire board around them was heated so hot you couldn't touch it without actually burning yourself, or you built up a lot of static electricity (like wool socks carpet and doorknob will show) and zapped the FETs. Neither one of those is likely.I suppose it is possible that I blew up the MOSFETs when I was soldering in the new capacitors. I know it's not easy to test the MOSFETs, it may be time to point on this controller and find another option.
However...another test is simply to disconnect the throttle, and power on the controller without one. If it still starts running the motor when power is connected, it's not a throttle connection issue, and is probably (but not guaranteed) to be the FETs.
bigedgar said:I'm now going to look for a better controller that suits this build. Does anyone have any recommendations? Here' are the specs I'm looking for:
- 36v
- 1000w brushless motor
- Must be able to handle at least to 50 amps
- Must have low-voltage cutoff
- Ideally it can integrate easily with my existing components (throttle, battery charger, brake) - here's a link to the existing, under-powered controller: https://megamoto.co/products/70-10003-00-controller-36v-1000w.html. If not I'm going to need to figure out how to connect things up (example - the Kelly KDS48050E looks like a solid controller, but its connections don't look anything like my existing connections).
This means you must be changing out the motor, too, because the link you give is for a *brushed* controller, which means you have a brushed motor, which a *brushless* controller cannot run.bigedgar said:[*]1000w brushless motor
Pretty much every controller has different wiring. There's no standards. Most of them hook up to the same types of stuff, but the actual connectors, wire colors, and even what features they have wires for, may be very different from one to the next.[*]Ideally it can integrate easily with my existing components (throttle, battery charger, brake) - here's a link to the existing, under-powered controller: https://megamoto.co/products/70-10003-00-controller-36v-1000w.html. If not I'm going to need to figure out how to connect things up (example - the Kelly KDS48050E looks like a solid controller, but its connections don't look anything like my existing connections).
bigedgar said:Amberwolf - It seems that my motor occasionally demands more than 30A, which is why I was looking for a controller that could handle more than 30A. My current controller brand is supposedly rated for 30A, but as you know it keeps on blowing up. Is your suggestion to find a better, higher quality 30A controller?
Almost certainly hall based, just based on it's looks, but you can test the voltage output when hooked to a controller. If the signal output goes 0v-5v over hte rotation range, it's a pot. If it is around 1v-4v ish, it's a hall.https://www.monsterscooterparts.com...-the-monster-moto-classic-1000w-mm-e1000.html. I can't tell if it's potentiometer based or hall.
