nikos7
Hi all
I am somewhat new to this forum and to RC drives in general, hence the problem I'm having with trying to make my simple setup run.
I have a 6 wire Astro 3220 8t motor with a Castle Creations HV140 controller and Turnigy 6s 5ah LiPos. I used the Castle link to set the controller to the following settings per Matt's recommendations:
Airplane fixed endpoint throttle setting
Motor startup set for soft
Throttle response high
PWM rate at lowest setting
Motor timing set for low
Originally I had everything wired up with a Magura throttle and a Throttleizer to provide 5v to the controller, but with no luck. So then I took out the Magura and Throttleizer and wired an Astro servo tester to the controller with 5v from a power supply as you can see in the picture.
Here are the steps I took:
1) I wired the servo tester to the controller (black to brown, red to red, white to orange)
2) I set the servo tester to zero throttle (1.0ms) and powered up to 5.16v
3) I hooked up the controller to the LiPo batteries at 49.2v
4) Immediately I hear the start-up tone and no LED flashing
5) I turn the servo tester to full throttle (2.0ms) and I get a bunch of lights flashing continuously but no action from the motor.
6) I back off on the throttle and the LEDs stop flashing, nothing from the motor
7) Every 8 sec, the LED flashes once.
Can anybody tell by my steps or the pic if I am doing something wrong?
