Help with Unite MY1016 controller conections
comfybob
100 µW
Please help,
I have Unite motor My1016, 24V, 250W, throttle and controller CT-302S9
www.tncscooters.com/CT-302S9.php
It works well when all the controller connectors are plugged to the scooter accessories like lights, brakes, horn etc.
I have transferred the motor to my bike.
The motor does not work when I plug only motor, throttle and battery to the controller.
I have bridged the Ignition Switch and the Brake Lever connectors.
Still does not work.
Are there any other controller connectors that require bridging?
Is there any other way I can connect the setup without accessories?
Many thanks in anticipation.
Bob
Measure and write down the voltages (relative to the battery negative) you get at each pin of each connector of the controller while it is on the working vehicle, and then do the same when it is on the non-working vehicle.
Compare the two and see which ones are different, then we can see about why they are and if they might be necessary to connect them to something to make them work.
I'd put in back on the scooter and keep unplugging things until you find out what makes it quit. Then you'll know the culprit. Probably the lock connector.
Thanks for useful common sense suggestions.
But stupid me, unfortunately I have reused some of the connectors and wires on my new setup
assuming I will never use the old scooter.
Any other ways to verify the connections?
Bob.
