strbmx said:
Yes its a Clyte. I am getting a new one this week. I will only be running 60V from now on...
How have people found the 60V 12ah Setup with Yardworks?
Hmmm. Mines a CLyte, 72v, 20a, PF, and 4s no problem so far, BUT I really don't push the 4s for more than a few seconds at a time. Even up 10% incline I've only gone 20 KMH for maybe 1 minute or so, although I have power to go up to 32 KMH / 20 MPH (1150 watts). I've tested this for 10 seconds or so, and yes 30+ KMH up 8-10% incline is easy to achieve.
Seems the 2 busted controllers here pop from heat, IMO, not from voltage itself. If it was just voltage, pop would happen at start with fresh batteries. I'm hoping to get a cheap backup controller soon. When I do, I will try really pushing 4s up the Gatineaus, while my ebikes warranty is still good. That said, perhaps I should wait until ebikes has these controllers in stock again, if they ever do. After Olympics ?
AFAICS, only 3 of us here running these batts. (?) Nuts And Volts (3s2p), yourself, and myself (4s + 2s). If anyone else, please delurk/speak up and share your experiences.
I drained all 6 batteries yesterday with the kids on a trailer again. About 25% at 350 pounds, and 75% at 330 (sans daughter left at daycare while son and I went to Ottawa for bike stuff at Bushtakah). When my 4s died just over half-way I knew I would have to slow down and do a bunch of pedaling. I did and batts finally died a few KM from home. Need. More. Batts.
At least bike can't tell the difference between electrons from YW vs. "Dangerous Cheap Ass Charger" (DCAC).
For whatever reason, batt 1 was showing 18.80v, while 2-4 were showing around 16.7 - 17.3v. Hmmm, I still suspect the battery that came with trimmer is better than other 5 batts. Since trimmer was first product, perhaps this was the first higher quality run to get QA approval from CTire.
Charged 2s from YW in 3.5 hours (One YW was 1.81 amps, other was 1.83, a bit lower than spec of 2a). Charged 4s from DCAC in 2 hours from full discharge to 21.11v indicated on top battery (Maybe about 20.99v real?). From 20.95 or so indicated voltage increased pretty fast. Yes, this is the point to switch from CC to CV, but I pushed it a bit because as soon as DCAC disconnected voltage would drop about 0.12v (was 0.20v earlier), and the batts wouldn't be fully charged and would have to top up on YW.
Same thing, more or less happens with YW. Pull the batt as soon as charger goes green, let them rest for a few minutes, put back on YW and LED would be red again for a while.
I think these batts have overcharge protection, because at 21.11v indicated, battery suddenly dropped to about 7v, so I disconnected DCAC. After 20 minutes or so, batteries had dropped about 0.2v from their post DCAC open circuit voltages. At this point the battery voltages were reasonably matched; all about 20.6 - 20.7v. I put them on YW to top and all topped to green in about 30 minutes.
Been pondering a "production quality" DCAC (for me, not manufacture.)
Thought about 240vac connection and $75 CTire 240v, 20a heater for 4s2p or even 8s charging. (Maybe later for heavy, home charger.) Thought about dual 120v chargers on separate circuits to do two 4s packs at once.
For now, have settled on idea for a single 120v, 4s DCAC. If I get a small, light heater, I can mount DCAC, a 120vac plug, and 120vac outlet on bike, and carry heater when needed and when my runs include access to 120v outlet.
I could have lunch or shop, or let the kids play at the park for an hour or so, and refill one 2s pack or about 40% of a 4s pack. With properly polarized plugs, and strategically placed 120v contacts on handle bars, I won't even need to lock the bike.
Outlet will allow me to test various heaters, or other high amp loads, like powerful lights. Heat in garage (and even on bike) will be nice when it gets colder, but might be nice to use amps for something useful, rather than wasting as heat when warmer out.
Light switches, plug, outlet, heater; bike will look more like a mobile appliance than transportation.
I think I may go back to 1s-4s switchable, for charging convenience when each battery gets 21v full. If battery 1 stays better, I could use 1s on that batt to get home. Might go with non-light switch toggles for DPDT instead of SPDT with 3 way light switches.
Forget solar cells. An outlet, an outlet, my kingdom for an outdoor outlet.
