nutsandvolts said:
mikereidis said:
80v fully charged and under load
You didn't get the magic smoke that I did, lucky you. What controller is that? And you didn't mention top end speed running 80V. How fast? I am also wondering what the range would be running full throttle on 80V, or maybe you don't want to run it that way?
I made a dumb mistake a while ago and killed a battery (actually probably just the bms), took it back
and they exchanged it no questions asked, not even a discussion about warranty.
If I did, I'd send the smoke and controller back to ebikes, under 1 year warranty:
Ctrlr is http://www.ebikes.ca/store/photos/C7220PF.jpg
Ebikes/Crystalyte C7220PF 24-72V 20A pedal first controller, IRFB4110 mosfets 0.69 kg (1.52 lbs) $145.00 Sold out
From http://www.ebikes.ca/store/
The controllers are guaranteed against failure for 1 year when used in the following setups:
72V controller with IRF4110 mosfets: All motor and battery combinations up to 84V .
I've never yet seen these batts fully charged over 20.98 volts, even after several days on charger. So 4s is at most 83.92 volts, just under the warranty threshold.
I beleive caps etc. are 100v.
Just how did you kill that battery, BTW ? I figure short circuits don't do it, so other than really high voltages, perhaps 100v reversed, these batts are almost electrically bullet-proof (for average stupid Joe CdnTire consumer warranty cost reduction.) I figure Joe might drop a tool or iron filings into the batt terminals, but he'd have to go out of his way to connect the batt to 120 vac.
Top speed, in theory, after a long period of acceleration on flat grade, is about 40 MPH or 65 KMH. At http://www.ebikes.ca/simulator/ I plugin:
404
19.1" wheel
80v (fully charged and under loads of 2-10 amps or so; maybe I should lower this for 20a operation)
batt resistance: 0.2 ohms
controller: 20a
ctrlr resistance: 0.01 ohms (4110s on 20a ctrlr ? I dunno. 14 gauge power wires.)
Peak motor power output I see is in the 1300 watt range. At 40 MPH it's about 1280 it look like.
Figures from that now defunct calculator indicate for 160 lb rider (I'm 174 clothed/equipped), 80 lb bike (Currently 72 for mine) and "road racer on drops" profile (Maybe roughly equivalent to my laid back recumbent profile ?) that about 1144 watts are needed at 0% slope. 1% slope is 1388 watts.
On my best battery I got 100 WH and 5.5AH running a nominal 14.35a load. At 20 amps, If I assume I get 5 AH then my 4s pack would be good for 15 minutes, or 10 miles / 16 kilometres. Using my assumed 100 WH per batt that's 40 WH / mile or 25 WH per km.
I could then run my aux 2s pack at full throttle at 30 MPH, 48 KMH for the same 15 minutes (note 20a controller plus 5 AH batteries at 20a, in series config with no parallel, will always give 15 minutes at constant full throttle, assuming you can always force the controller and motor to consume the full 20 amps.)
So I'd go 7.5 miles or 12 km on the 2s pack, about 27 WH / mile or 17 WH / km. I'd have to pedal the last 4 km home.
Need 4s x 2...
All rather academic unless you have a long, straight, level test track and no wind issues etc.
I had thought I would be comfortable at 50 KMH and could push it to 60. 40 KMH is the fastest I've gone a few times, the first time on maiden test run, and it was easy and quick to get than on 2s with a 2-3% downhill. I'm more comfortable limiting myself to 30 at most, with 20-25 being average.
If I had some proper safety equipment for elbows and knees etc. and a good, clear, straight, reasonably safe place to try (probably a good road, like Gatineau roads when closed and without lots of people like Alcatel Sundays or whatever), I'd be willing to see how well 50 - 60 look. For a while at least.
Also need better brakes, and perhaps tires. I'm still averaging one wipeout per 44 KM, easy Ottawa River run trip. Today some guy came into my lane on a corner, and my brakes are marginal, and I jack-knifed the kid trailer.
Only injury was a minor scratch on my leg from the under seat steering.
Some pics and a bit more info on my latest mods and Ottawa River Run with 350 lbs of bike, kids, etc .: http://endless-sphere.com/forums/viewtopic.php?f=3&t=5749&st=0&sk=t&sd=a&start=30#p88977
