I have some finalized prices for you.
It looks like the single stage drive will come in at $220 with FW adaptor (no freewheel, though). There are so many freewheel choices that I felt it best to leave that up to each person. That $220 is for the drive itself. Any custom fitment would require more time, and a bit more cost (not much). Things like strange motors that don't lend themselves to a simple slot mount, anodizing, polishing, and that sort of thing.
You will remember the E-Box was going to be $150. That was without a FW adaptor and it was a much simpler design. That design was much more restrictive, though and not expandable.
The two stage drive will be $380 to $400 depending on a few things.
There are a few options available to chose for each individual setup.
#1 Plain or polished? Anodized?
#2 Ratio.
#3 Wattage output.
The first stage of the dual drive (and the single stage drive itself) will be configurable in 3 ways. First is 9mm wide 5mm pitch belt on the first stage (all two stage drives will be #25 pitch chain on the secondary stage). That drive is good for 1500 to maybe 2000 watts. It is more efficient, but may require an idler to work above 1500 watts. 2000 watts is the max for 9mm wide belt. Second is the 15mm wide 5mm pitch belt. That is good for 3.5 to 4kw. It can handle up to 5kw if the belt is run very tight and the motor pulley is high enough tooth count for enough tooth engagement. Lastly will be #25 pitch chain from motor to jackshaft. That setup will make a bit of noise, but it will handle up to 8kw (if I have it figured right) or more. For those who want huge power without any chance of skip and do not mind some chain noise, that is the highest power option.
Anyway, I am not taking money just yet. I am still waiting on bearings (no biggie) and FW adaptors. I will be ordering some pulleys and sprockets individually at the beginning to setup each drive semi-custom. That will make each order a somewhat special deal that will take a week or so to get each item in stock that is needed for that particular drive as well as machining the motor mount for each motor. As I get a handle on the perfect ratios to stock, typical motor mount hole spacing, and what most people want, I can stock parts accordingly.
I know it has been a wait. But, for mechanical R&D, it has actually gone pretty quick. :wink:
Moving right along!
Matt
