johnrobholmes said:
What attributes "matter"? It has a wider space between spoke flanges, the wires don't exit the axle, and the slightly smaller diameter may actually allow for a wheel build that doesn't break spokes constantly. Looking good to me so far.
1.813mm^2 motor wire x-section with 1.62mm^2 phase leads?
From a visual guess, <35% copper fill in the slot?
And most important, hubmotors get better (in all respects) as stator diameter grows. Efficiency is linked with the speed the magnets move past the stator, getting wider helps in a linear fashion with torque production, getting larger around helps with torque production and efficiency (magic-pie was something taking a step in the right direction).
Justin's flux measurements with back-iron testing on the flux rings showed going beyond 0.8mm (IIRC) was just excessive weight, and iron doesn't conduct thermally worth a damn compared with Al.
The decreased stator mass, yet increased active surface area could actually be a cooling advantage though. Remember, unlike was was posted, mass has no impact on cooling, only delaying temperature change. This stator may handle higher continous power, yet be faster to reach a danger temp under burst power situations (I call that a good trade IMHO).
That said, the 9C looks like crap as well, but tends to work pretty damn well in practice. This could turn out to be another unexpected diamond in the rough, as big performance factors like magnet strength, flux gap distance, lamination material, thickness, design etc aren't able to be seen from a few quick photos, and if they nailed those aspects, it could rock-and-roll.
I think the seller is going about this
PERFECTLY, and the same way I would do it myself in his shoes. Much respect for taking advantage of this great community for doing a killer waranty for folks valuable real-world testing, finding the limits, advantages, potential issues etc. This is definately the group of folks to use for putting a new motor through it's paces.
johnrobholmes said:
I don't know if you saw this:
http://endless-sphere.com/forums/viewtopic.php?f=2&t=14580
But I made a couple simple ebikes for my parents 9c, 72v 15Ah LiPo, 50A controllers (which sit in their garage collecting dust).
