I have these battery packs ( 4 X ) since end December and I am not satisfied about them and especially not about the claimed 30c cont. and 40c peak power output.
They do give me more than 4500mAh but this is the only plus for me
I want to make 2X2 packs or 39,6 V and 9 Ah.
Here are my findings written in the "local" forum:
" I recently ordered and recieved 4 Turnigy 6S2P lifepo4 4500mAh flatpacks for my 500 watt electric bike.
These batteries are fairly new items available from Hobbyking with practically no reviews or real-time experience from buyers, so maybe I am one of the first to have some experience with them, and let me tell you, before you make the same ( expensive ) mistake I did.
They are CRAP and DO NOT even come close to their rated 30C cont. - 40C peak discharge rating, which means that theoretically, you could discharge these batteries in about 2 minutes.....or put a 2500 + watt drain on them, which is definitely A BIG LIE. and would probably ruin them in a few cycles.
Furthermore these batteries behave more like NIMh cells than lifepo4 cells running from full until empty like, strong-good-fair-tired-coma, instead of strong-strong-strong-good-tired,
I just tested one of these on my electric bike and a WATTS-UP!!! monitoring device, firstly balance charged the battery until all 6 cells read 3,6 volt.
It was the 4th charge on this turnigy, so he ( she ) should be virgin-like.
Connecting it to the bike and just free-wheeling it with light braking applied until about 150 - 200 watt was consumed,i quickly noticed after about 10 minutes that the cells became handwarm ( 30 to 35 celsius ) in a +5 degree enviroment and there is a rather large voltage drop until 16,5 to 17 volt, at this point there was about 40 % of rated mAh drained from it, and I stopped for a minute, slowly seeing the voltage come up to 20,4 volts again.
Now for the test I applied some harder braking and let it freewheel off and on for about 6 minutes ranging the load from 100 until 350 watts,
the voltage drops were severe under the higher loads, one time reading only 12,7 volts, this can not be healthy for a battery which has 19,8 volts nominal and has a "30C" discharge rating, with the 350 watt load applied this is only about 15 % of what the battery " in theory" could handle......
The lifepo4 was now warm ( about 40 to 45 degrees ) warmer then I ever felt from a Lipo from turnigy with a lower C-rating and capacity after some hard flying.....
Then I stopped again, and saw the voltage creep up till 19,1 volt, according to the watt-up there was 3400 mAh consumed, and tested some more, with the last 25 % battery mAh left I let it just drain at 50-60 watts for about 15 - 20 mintutes until 4600 mAh was reached.
Again voltage dropped until 14 volt under this slight load and no-load voltage was 18,2 some 3 minutes after the end of the test, suggesting there was still some life in it yet. ( like a 90 year old smoking alcoholic with diabetes )
I did this test because with all 4 packs on my bike it felt sluggish in preformance when climbing slight hills which raised some question markes in my head because they should preform flawless untill about the last 10 % just like lipo's do
All in all: Hobbycity should remake/rename the labels on this battery and discard the "zero" in the C30 rating and making it 3C instead, and even this is IMHO on the high side, the voltage drops under load are unhealthy for a long and happy battery life.
On the bright side, they do meet their rated capacity of 4500mAh, but only if you are willing to drian them slowly in like 30 minutes.
I just hope that the 1000+ cycle life is anything they say it is...........
Its not that I don't like hobbycity products, of the many $$$ spend here this is the first time I'm really dissapointed in a product.
350 Watt should be a walk in the park for these turnigy's but PLEASE BE WISE and keep the $69,99 w/o shipping and customs in your pocket.
Sorry for the big write-up, any comments/suggestions are welcome.
CDM, Belgium."
