Green Machine
Has anyone considered a Hobby King Scorpion motor in an ebike application?
http://www.hobbyking.com/hobbyking/store/__17401__Scorpion_HK_5035_500_Brushless_Outrunner_Motor.html
Seems pretty good...according to hobbyking:
"Scorpion HK Series Brushless Motors are built from the best materials available, and are designed to provide both quality and performance at an affordable price. Scorpion starts with high quality aluminum alloy parts that are produced on the latest CNC milling machines. The stators are made with high quality laminations to give maximum efficiency, and minimum Eddy current losses. The stators are epoxy coated to prevent shorts, and are wound with wire that is rated at 180 degrees C (356 F). The magnets used in Scorpion Motors are rated for operation at 200 degrees C (392 F), making a motor that is virtually impossible to burn up in normal use."
Could this be an alternative to an astro motor?
