shawname
This is my home assembled electric Yuba Mundo.
I wanted an ecargo bike that would go 60 miles on a charge and tote a weeks worth of groceries and my girlfriend- all at the same time! My needs were more demanding than the products on the market could meet so I chose to assemble my bike.
I bought a Yuba Mundo frame with panniers and a front basket. I used a Ping 36 volt 30 amp battery and a 500 watt Golden Hub Motor that I have had on several other ebikes. I bought new Schwalbe Fat Frank tires. They are cushy and support 330 lbs per tire. I used a 7 speed internal hub that I had on another bike, and a 3 gear chainring in front. I added a car headlight sized 2200 lumen LED front light from Super Bright LEDs, and an LED truck flasher on the back. I converted the voltage to power the LED lights from 36 to 12 using a Green Galaxy Dc to Dc convertor from Thunderstruck motors. The lights burn just 20 watts and add enormous visibility and safety. I use a Cycle Analyst as an energy gauge, and find it invaluable.
The battery weighs 25 lbs and is mounted in the front basket. The basket is rated for 50lbs. It helps balance out the weight when the tail of the bike is loaded. I would have preferred to mount the battery lower, but I needed extra space to carry a larger battery, and chose the simplest option. Because the Yuba front basket does not turn with the handlebars, the weight is not noticeable once underway, and I can even ride with my hands off the handlebars. The front “hood” has proven to have other benefits, as there is plenty of space in there to manage the wiring and to store small valuables.
The bike has a tested range, (with no Leslie) and with me spinning the pedals, of 97 miles. The extra weight of Leslie and groceries costs 30% of my range. I met my design goals, and have a great car replacement vehicle.
Here is Leslie and I out shopping this morning.
I am building a 5 amp charger for the 36 volt Ping battery that will allow it to be charged directly from photovoltaics or a 12 volt battery array. I should have the first prototypes finished in a few weeks and will report back.
Now I look for opportunities to ride. I am reminded of when I first got my drivers license. I was always asking my mom if there was anything she needed at the store:
Mom, don't we need a loaf of bread?
No.
How about a half gallon of milk?
No!
How about canned ravioli? I don't see any.... Give me the car keys, I'll go get some for you!
No.
No!
