liveforphysics
100 TW
I've not balance charged for the last ~100 cycles or so.
If you start with good matched cells, and test them to ensure they are matched and consistent, you can start with them balanced, and they will stay balanced until some cell in a group becomes weaker or develops a tiny increase in self-discharge, or if the pack has only the outside cells cooled much better than the inside cells, etc etc.
I've never had a BMS on any of my bikes, and likely never will.
The danger here isn't not having a BMS, it's simple enough to just check with a multi-meter once in a while to make sure it's staying balanced.
The danger is starting with an inherently dangerous chemistry cell in a sketchy unknown condition (expired shelf-life and/or various states of used etc), and ALSO not having a BMS or any way to even get a heads up if you're having a cell reversal in discharge or an overcharge event that explodes or vents fire unattended in your garage etc.
All it takes for that to happen is any single cell in the pack to develop a tiny dendrite growth or separator break-down (which both happen on older cells), which drains one bank of cells without you knowing.
