67spyder
You are right, the 32ah capacity just barely eclipsed the fact that they are pink! I went with 12p config because the C rate is so low with the laptop chemistry and there are six cells in each laptop battery.
Some shots of the jig.
A string of cells ready to be soldered
The tabs folded over and tinned.
soldering a piece of 12Ga wire
One end done, going to remove the string, flip it over, put it back in the jig and solder the other end
The finished string of 12
Repeat 28 times
I charged each string individually to get a feel for capacity and to start with a reasonably balanced pack. All the strings took right around a 27Ah charge
I assembled them into a pair of 6s packs with a 2s pack to make 14s because that is what fit into the battery box.
I will post pics of the finished battery in the battery box tomorrow.
Repeat 28 times
