http://i.imgur.com/49f8Ow7.jpg
SORRY ABOUT THE UNFLATTERING SETTING FOR THE PICTURE I was in a rush
Im almost done with this homemade e bike and had a few questions for you guys. Im running a 1hp (maybe .9hp? I cant remember) golf cart starter generate motor, with 2, 12V scooter batteries in parallel connected to a 12V 50A motor controller. If you need more specs let me know.
I was wondering if you think the gear set up will be enough. I have a 11 tooth gear in the front on the motor, and i just bought a 60 tooth gear to attach to the rear. I used the stock rear cassette, but there wasn't enough torque to get going, so I figured this gearing should be better, but is it enough??
Also, is it legal to ride this as a bicycle if I don't have pedals? I'm assuming it should be ok, because I can argue that there are pedal-less bikes.
Finally, I think my twist throttle only goes to about 2k when the initial pot on the motor controller went to 5k. I may be reading this wrong though, because I ordered a 5k throttle. How big of a deal would it be if I put a 1-2k resistor in series with one of the 3 lines?
