How do I get reverse on an Infineon controller?
mrbill4108
Ok guys I’ve looked through the different posting and I’m a bit confused. I see where people talk about getting reverse with an Infineon Controller but I can’t seem to find what I need to do to get reverse. I am helping a friend put an E-BikeKit.com (9 continent motor & Infineon Controller) on a trike and he needs reverse.
So could one of you please help me get him reverse?
Thanks a bunch,
Bill
Put a switch between DX3 and GND pads.
ON = Reverse
OFF = Forward
Note: You can use the smallest switch & wires you can find. ( No current involved )
You might also want to set a reverse speed limit using the "Converse speed" setting in Parameter designer.
Can I switch between forward and reverse without turning off power to the controler?
Thanks again,
Bill
