ebike4healthandfitness
- Joined
- May 19, 2012
- Messages
- 1,283
How important is a suspension fork for your street ebike?
What wheel and tire size do you use? Tubeless or tubed?
If your intention is to go over 20 MP/h, then suspension is a must. Look at street motorcycles—they are fully suspended, and with good reason. Hitting a bump at high speed without suspension to absorb the impact could be disastrous.How important is a suspension fork for your street ebike?
non suspensioned 32" would probably be super nice at pedal bike speeds even on crappy-ish roads. But mine are worse than that!
Cycled for years without suspension and my ebike is without suspension. I have Vredestein Staccata 100/80-10 tyres at 18psi up to 35mph (Though I rarely go over 15-20) I sacrifice some range for comfort. Over 20psi on these tyres starts to get uncomfortable.
I dont need suspension, however, id add it if i could find a nice solution for 16" wheels. The forks are either too long, or too cheap withput adjustable rebound. Id happily make my own, but cant come up ith a decent idea.
I guess its a combination of things. It becomes too much like a motorcycle by that point and ive been there done that. It becomes less about the journey and more about getting from a to b which is not what i do. I purposely try to use only canals country lanes parks and cycle ways. If im on a boring regularly road with traffic ill travel faster until im back to somewhere without traffic.You probably have the tires with the greatest sidewall height (at 3.2") in this thread coupled with my guess is the lowest tire pressure (18 psi max). This means your tire is capable of the greatest amount of deflection in this thread though overall tire diameter is only 16.4".
Can I ask why you rarely go over 15 to 20 mph?
Not at all, if anything its when im going slow i sometimes wish i had suspension, as when im going slow im usually not on a road but somewhere much bumpier! However i carry a little battery pump with me, only takes a minute or so to adjust the type pressures. The wind noise is the most annoying thing at 35mph. However, the bose noise cancelling headphones with windblock mode help a lot.So it is not because of lack of suspension?
