want to build
Regular
- Joined
- May 18, 2018
- Messages
- 291
HI im fromm canada and i d like to build required battery to use with a kit i can import o it coud be from ebay.ca too
i looked at
AW 26"x1.75" Rear Wheel 48V 1000W Electric Bicycle Motor Kit E-Bike Cycling Hub Conversion Dual Mode Controller
from https://www.amazon.ca/gp/cart/view.html/ref=nav_cart
and i would try to find good batteries maybe these https://www.ebay.com/itm/99-SANYO-18650-2200MAH-UR18650F-LITHIUM-ION-BATTERIES-POWERWALL-EBIKE-DIY-CELLS/183175829747?hash=item2aa62158f3:g:XJ8AAOSwAwFatByn
from alarmhookup seller on ebay.
MY NEEDS
i ll use the bike to assist me with cargo in hills and flat but i will keep pedalling moderatly.
question 1 how may battery cell do I need to do 70 mile (while pedalling moderatly) with the hub presented 48v?
question 2 what about if i build a 24 volt battery pack for the hub for 70 miles while pedalling moderatly? im open to suggestions
question 3 should i use a different motor ?what would be the advantages ? how will less watt lower volt affect the use?
question 4 my actual tires are 28 inchs . can i put the 26 setup on it ? any modifications to do? here is my bike https://www.norco.com/bikes/city/hybrids/yorkville/yorkville-stepthru/
i looked at
MY NEEDS
