judson
Hey all,
I'll try to make a long story short. The first battery I bought to use with my bafang mid-drive was a 11.6Ah 48v in a dolphin case with a physcical on/off button integrated into the case. I like this battery but I need it for another project. The battery I want to replace it with is a 13.5Ah 48v in a jetpack case with NO on/off button.
In my old set up, i would power on the battery by pressing the physical button then press and hold the on/off button next to the PAS controls. So here is my question, if I replace this battery with one that doesn't have a physical on/off button, will the software on/off at the handle bars suffice to power down the system? or will some thing still be 'on' somewhere?
It is a bit confusing because these units have an integrated controller. My worry is that even if the display is off, the controller would be drawing power.
Thanks for any thoughts!
