ikeonabike
10 µW
- Joined
- Mar 8, 2017
- Messages
- 5
Hello-
I've read tons of posts on ES while preparing to build my first ebike, but this is my first time posting.
I'm building my first electric bike from a 48V 1000W rear hub motor I picked up on ebay and a 48V 18ah (5-parallel, 13-series) battery I picked up on Aliexpress. I believe I have hooked everything up correctly, but I'm getting no juice. Nothing happens when I turn the throttle, and nothing shows up on the LCD screen.
I thought the problem might be the crappy crimped bullet connectors that came with the controller, so I replaced them with soldered XT60 plugs. Didn't help.
I have tested the battery with a multimeter and fully charged it shows 53.9, which is slightly lower than the company's claimed charge cutoff voltage of 54.6. I don't know if that means something is actually wrong with the battery.
How do I figure out if the battery or the controller is the problem? The battery company says it's probably the controller and the motor company says it's probably the battery.
Thanks!
Thanks!
