Hwy89
I decided to try pedal assist on a new bike I just put together. It has a q100 rear motor, a S12SH sine wave controller and a LCD 5 display. Everything works just fine with the throttle but I can't get it to work with the pedal assist sensor that I just bought. The sensor mounted easily on the non drive (left) side of the bike. I made sure that the arrows on both the sensor and the magnet ring point in the direction of pedal rotation and the gap between the two is less than 1/16 of an inch.
I spent half the day today programming and re programming the L C D 5 with no results so I put my volt meter on the connection to the controller. Negative to positive reads 4.26 volts and negative to signal 1.4 volts but this is a steady state. The voltages do not change when the pedals are rotated forward backward or stopped. I have no idea what I should be seeing but I assume there should be a changing voltage coming from the sensor.
Unfortunately I don't have another sensor to compare with so I'm hoping to get some advice from the forum.
