LI-ghtcycle
Heya all, I decided I should start a new thread since I am going a new direction for the drive type of my cargo/touring bike. Not much to show, I have all the parts and pieces, just finding the best way to put them all together.
Here is the bike:
It has the Nuvinci CVPT hub in back, soon to have the second fixed cog for the hub motor drive chain.
Here is the motor, Amped Bikes 9 x 7 DD Hub motor.
This is a rear hub motor, and it has much wider spacing that I need, so I am going to so some "shade tree mechanic" machining, starting with an angle grinder, finishing with a file.
Here is the result:
Here is the carcass of the old exercise bike that will be donating it's drop-outs and probably that entire horizontal square tube (or at least enough of it to make a good strong "C" channel) to mount on top of my rear rack.
The only question now is weather to take the axle (assuming it's not too hard to get out) to the local machinist to get threads down further, or use some kind of bushing to make up the difference between where the threads end and the new flats of the axle go.
I'm really pleased with how well my "shade tree" machining has come out, it's really even and was just eye-balled, but my caliper shows nearly identical spacing between the end of the shaft and the new shoulders on the axle (can't see day-light in the difference between the two shoulders with my calipers. 8) )
Here is the bike:
Here is the result:
