Hybrid moped wattage?!
Crazycow
Athens, Greece
Hello mates and thank you for this forum :)
I have a moped, an old school one with pedals. It's a Peugeot Vogue and I love it! I had it in flatland Belgium and I have it in hilly/mountainous Athens :)
The problem is that I'm 135kgs, and it had trouble going uphill as well as accelerating. My idea that has already been done is to add a hub motor for these two elements.
A full tank of gasoline is ok for about 200km and it hit 60km/h easily with the 50cc two stroke, therefore I don't care much for speed or range. Although the 3000w QS motor says it could reach 120km/h I am not that crazy either.
So please, I need first your opinion on wether I should go for 1500w or 3000w! I guess double the watts, half the range?
And what about battery size? What do you suggest?
I am having trouble estimating a realistic range for using the electric motor to accelerate and climb hills meaning in a supplementary way to the gasoline one... Has anyone done it? What is your input?
Thank you very much!
What size motor you have wont determine what range you get. The question is how much power will you use, and for how long? In a hybrid system you probably wan to keep the electric stuff rather small. Will you have a battery capable of powering the bigger motor? If you plan of a max power of 7-8kw for relativly short periods the 1500w motor probably is more than enough.
