cal3thousand said:
ebikedelight said:
This modification has resulted i me being able to push my 1000 watt motor, to 2500 watts and it only gets very warm..compared to it usually getting quite hot.
I appreciate your idea and I'm not shooting it down. But this particular claim that I quoted, doesn't really mean much. First, who said it was a 1000W motor? The motor manufacturer did and that is not standardized. Next, you don't tell us how long you can go 2500W and 'only gets very warm' is a very imprecise metric.
For example, a crystalyte HT3525 in stock format can do 2500W for 22 minutes before it 'overheats'. At 1000W, it will never 'overheat'.
The real question is whether your motor now has a higher capacity for heat shedding than previous.
BTW, what mystery motor are you working with? Any pics yet?
motor is a generic yescomusa 1000 watt D.D. rear hub motor off ebay for around $200 shipped with controller. Im not using stock controller , im using a Lyden which is pumping around 52 amps at 50 volts into the motor for certain sections of the trails I ride and hilly back roads that are made of gravel.
im not trying to convince anyone to do this mod...im just reporting that I came up with the idea, and am happy with the results. I personally would never try to run my motor at 2500 watts for 22 minutes , because I dont need that type of performance. I am comparing how hot my motor used to get, compared to how hot it now gets with the heat sink mods
running the same distance/ trails with similar throttle usage . My own experiments , although not 100 % precise, have proven to me that my modification works great for my needs/ expectations. The one section of trails I ride, my motor always got hot after the run , it now is " warm to very warm after the run....and the only thing I changed was drilling the holes and covering the holes with the heat sinks . Thats enough proof for my needs , but I understand if other people are skeptical.
