o00scorpion00o
Hi Fury,
It was 25C I was after, but I've no doubt they will have them now that I have my other 2 packs, lol
Yeah BT means that there is no limit for the first 1- whatever you set it to take off harder!
The battery limit means it limits the current drawn from the battery, phase is the limit to the motor, but you can fry your motor and fet's if you go over the limits of both!
I think though if you limit the battery current too much you won't be able to climb hills or accelerate too quick or be able to hold your top speed so good, But it's good if your battery can't take the amp draw!
Phase currents will allow you to go accelerate faster or climb hills better but too high and it's bye bye phase wires and motor! It's nice to be able to adjust both though!
I long for the day there is an integrated control system where you adjust everything from the handlebars, the cycle analyst if good, but there is too much of a delay in limiting, I would rather it software based directly to the controller!
A temp sensor in the motor linked to the controller would also be nice along with temp monitoring display, slow start option would be nice also.
I don't ask for much do I ?
Mark
Mark
