scob89 said:
600W at 12V won't get you much, but 600W at 120V will get you much more.
No, it won't--600W is 600W no matter what--it's the same amount of total power either way.
It's just that at 12VDC, it's going to take 50A to make 600W, and at 120VAC (from your inverter) it's going to take a tenth of that current for the same power, during the peaks of the AC cycle, to make the peak of 600W. (to get an average power of 600W, it'll take a higher current, IIRC, but math is not my friend so I can't give you the numbers on that
Just accept the fact that I am going to build it regardless of what anyone says.
I, for one, would like to see the results; I just don't want you to be disappointed in the results, and go in expecting more than it's capable of, at those limits. It's fun to do projects like this; to repurpose things and push limits of them.
I've already been there myself, in my first experiments with motors and bikes, and if I'd had better advice when I started, I probably would've gotten further along faster than I did, and wasted less money on stuff that couldn't work like I needed it to.
Do I get a 1000W inverter for $80, or wait for a coupon and the a 800W generator from harbor freight for $89. I have other uses for both, so no money wasted. I'm leaning towards the inverter for my solar system.
First, make sure you check out the specs on the inverter, because some can be used with motor loads and some can't (if they don't say they can, they might work, but might be damaged or destroyed by them). Some of them may damage your motor controller, too.
Don't expect me to answer any more questions on this forum, there are better forums out there. Sure they still say it won't work, but atleast they are not flat out calling me a dumb person, or a troll.
Not everyone here is doing that, so punishing the rest of us that are trying to help you, for the sins of a few, doesn't seem fair.
It's your project and your choice, though.
