Hillhater
100 TW
You miss the point.wjr said:Hillhater said:ploughing is all about torque, not kW
of course I can slow down.
But you have to get your act done when winter is coming...
Even at current ploughing speeds, ( 5 - 10.0km/h ?) your tractor is likely producing 50,000 Nm at the drive wheels.
Even with a single plough your 20kW device will need 10,000Nm for a similar ground speed on a similar wheel size.
And you will take 5 times longer than present to finish the ploughing !
....wjr said:.... since electric energy is alread equivalent to mechanic, no need to go the lossy 30..40 % thermal cyles any more.
Not true. The kw you harvest from your roof, will see significant losses before they get to pull your plough.. at least 20%.
?? 5.0l/h/hp ? Would suggest your current tractor consumes 500 L per hour whilst ploughing ?...seems unrealistic ?wjr said:..
My rough estimate is 5 l/HP and hour, but I think with slower speed, lower weight, motors close to the axle w/o complex transmission stuff, I came to my estimte of 3 kWh to replace one l diesel fuel.
Just a rough order of magnitude...
But even at your 3kWh per ltr, that would tell us you will need 30,000 kWh/yr or 15,000 kWh just for ploughing.
If you want to get your ploughing done in say, 3 months,.. that means 170 kWh per day needed.
You would need either 2x 200kWh battery packs, or a expensive complex power distribution and tether system
Ah ! You already have your own solar farm .wjr said:Currently I have 150 kWp on my roofs, maybe will be double the next years...
Very handy. But i assume you have a need / use for that already ?
Your tractor requirement of 30,000kWh should be considered an additional power demand
