Matt Gruber
just a rant.
very disappointing.
i won't be "upgrading" to brushless until they are reliable.
very disappointing.
It's disappointing to me as well, but I don't think it has anything with to do with the motor as it does with the controller. I haven't cooked my controller yet, but I haven't run it everywhere on 72 volts yet either. So I'm not going to press my luck just yet....Matt Gruber said:just a rant.
very disappointing.
Ypedal said:I have not cooked any either, and i have run them at 95v a few times.. 80 all the time.. and everything in between.. i know DOM from australia also runs 100v with lithium ...
There are 1000's of these motor/controller combo's in use daily all around the world..
From what i've seen and read.., if you plug them and run them for a 100 miles without problems.. they will run just fine .. the failures usually happen as soon as they are used.
I'm keeping a very interested eye on this..![]()
I believe all of the Crystalyte controller failures occurred when running at 72V or above.
Proper DESIGN and quality componrnts are a must for reliability! But cheap crap from China is all you get. If you want something better there IS ! But at American prices. "built and designed in the USA" or europe. Great motors also do not come from China. The only hub motor/controllers that you guys keep telling me are marketable and made by thhe 1000s Someone is making a great profit off of you. So why should things change?fechter said:Other than controller issues (which could easily be solved by proper design) the motors themselves are nearly bulletproof. .
For design work about 10 grand then about $60. each for 1000 of them. The company will NOT make small batches unless you pay for the design work.Even then 500 units might cost double the price if they will do it at that small volume.BiGH said:god that is a work of art that controller.
I do tend to agree that the controllers included with the crystalite kits are quite sub par.
I was thinking of re-making a one, in a custom case, but might just go for this one insted.
how much do they cost though?
That's the Ol DYI go at it that that the available ebikes need to work decent.For the performance of available ebikes or kits the cost is a joke for what you get.New cars will soon have electronic goodies you can get cheap at junkyards for ebike DYIers.Right now ebike systems are in the dark ages.BiGH said:hahahhaha sooo expensive. I think I'll just design one myself insted.
sure it would take longer, but it'd be hella interesting, plus my main reasoning behind it was the mounting of a heatsink and reliable components.
programmable controller would be cool, I plan to eventually make one / have one made so i can program it.
A well designed high wattage capable controller would sell rather well I would think
something like a 36v-108v 60a max (i'd rather over-engineer then roll back the specs) controller in a good custom heatsync designed to fit somewhere specific in a bike, like under the rear seat or on the frame somewhere
EbikeMaui said:That's the Ol DYI go at it that that the available ebikes need to work decent.For the performance of available ebikes or kits the cost is a joke for what you get.New cars will soon have electronic goodies you can get cheap at junkyards for ebike DYIers.Right now ebike systems are in the dark ages.
EbikeMaui said:This double deck circuit board has 4 times the components as a Chineese ebike controller for a good reason.It weighs only 8 ounes and is a 3" square package. It has a 27 amp limiter and will run from 18 to 80 volts. I put over 20.000 miles on one like this without a single failure.Including going up a 10,005 ft high Volcano several times powering a ebike with 300 lbs of gross weight.All the components are Mill Spec. The orriginal design is used in F-18 Fighters where any failure is NOT exceptable. They would cost less than half of the price than I can buy a Crystalyte controller for IF a few hundred were made. If indeed there is a market for quality, smooth, long lasting, efficient, BLDC controllers that have no problem handeling 1600 watts of power why do people insist on Chineese junk ? Is there no dealer that can figure this out? :lol:
Unfortunatly great controllers need costom design work and need to be made in volume to get a great price.FYI the Programable Sevcon controllers with regen are rated at 5 kw and will provide a great response for testing many BLDC motors at $500. a pop. But doubt that they will ever POP! and they ARE available 1 at a time.IMO these would be the ones to use if you do want QUALITY and LONGEVITY . It takes much more than high quality fets.It takes ADVANCED DESIGN WORK!!!knoxie said:EbikeMaui said:This double deck circuit board has 4 times the components as a Chineese ebike controller for a good reason.It weighs only 8 ounes and is a 3" square package. It has a 27 amp limiter and will run from 18 to 80 volts. I put over 20.000 miles on one like this without a single failure.Including going up a 10,005 ft high Volcano several times powering a ebike with 300 lbs of gross weight.All the components are Mill Spec. The orriginal design is used in F-18 Fighters where any failure is NOT exceptable. They would cost less than half of the price than I can buy a Crystalyte controller for IF a few hundred were made. If indeed there is a market for quality, smooth, long lasting, efficient, BLDC controllers that have no problem handeling 1600 watts of power why do people insist on Chineese junk ? Is there no dealer that can figure this out? :lol:
I totally agree with you on this point Randy, some of the Chinese controllers and hub motors are piss poor in quality, but they are cheap however the controller issue is one that does need addressing, whats the spec on your controller it sounds interesting, can you post pictures and maybe details of where we could get one from? price and availability, I vaguely remember seeing a picture of it on v is for virus.
Cheers
Knoxie
EbikeMaui said:It takes much more than high quality fets.It takes ADVANCED DESIGN WORK!!!
Bionix whimpy controllers cost $1000. Go FIGURE ! ???
