Hello, I have an emmo monster and after 6,500 kilometres my front wheel bearing gave out. The axle is 270mm and 10mm diameter.
My problem is some of the assembly kind of got chewed up and spit out, one of the parts inside the hub got sheared and I can’t find the name of the part.
Only one sides bearings gave up but Im going to replace them both, is there a good video you can direct me too, I’ve been looking for a bit now, it’s the spacer inside the hub, what’s the name of it I think the top of it is sheared off, if you can help or replaced this before it would help, thanks
