Success. The cable works a treat. I scoped it out first, it gives a 3.3 volt signal.
Loaded up the settings file that Keywin sent me so that I didn't change anything, hit the transmit button, plugged it in and away it went.
Below is the conversation the pc has with the controller.
Port opened by process "Parameter Designer.exe" (PID: 2868)
38 38 38 888
Port closed
38 38 38 888
Port closed
38 38 38 888
Port closed
38 8
Answer: 19/02/2009 11:22:33.03764 (+0.0000 seconds)
55 U
Request: 19/02/2009 11:22:33.24064 (+0.2028 seconds)
02 0F 33 25 C7 04 CE 00 83 83 83 0A 96 00 01 06 ..3%Ç.Î.???.?...
68 6B 00 00 00 00 00 00 00 00 hk........
Answer: 19/02/2009 11:22:33.36564 (+0.1248 seconds)
55 00 U.
Port closed
Request: 19/02/2009 11:22:33.91164 (+0.5460 seconds)
38 38 38 888
As you can see the program sends a series of "8"s until it gets a reply of "U", it then sends the setting info and the controller confirms it with another "U" and a NULL character. It then continues to send "8"s, I assume it is waiting for the next controller to program (production line style).
Here is the setting info I used.
