Hi!
This is a very interesting controller!
I assume that ecrazyman on eBay still sells the old version, right?
I have a couple of questions concerning this new controller.
1) Is it possible to drive a Crystalyte 406 motor?
2) Can it be modified to work with 36 or 48V? I assume I have to change the low voltage cutoff somehow, is it possible to make this adjustable with a poti or so?
2a) I think the controller power supply needs to be modified, too. I assume it need 5V. Would it be possible, to run it with a 5V step down converter?
http://translate.google.com/translate?u=http%3A%2F%2Fwww.rc-planes.de%2Fproduct_info.php%3Finfo%3Dp403_ELE-UBEC-A3-HV.html&sl=de&tl=en&hl=de&ie=UTF-8
3) Is it possible to adjust the maximum current by soldering in a poti somewhere? I am not sure about which maximum current is best for my planned setup. And I want to be able to include a "Cop mode", selectable via magnet switch or so, to reduce the power considerably, by changing the resistor value determining the max current.
4) Where do I get fitting thumb or twist throttle controls? Do the ones ecrazyman sells on eBay fit?
Thank you very much,
Julian
