solarbbq2003
- Joined
- Apr 7, 2007
- Messages
- 500
any results for the bafang test at 48v or over with infineon? no load rpm? or road testing results on given amps/volts? or too early at this stage?
Look here: New Infineon v Old PIC Controller - A 48V Bafang PMGR Testsolarbbq2003 said:any results for the bafang test at 48v or over with infineon? no load rpm? or road testing results on given amps/volts? or too early at this stage?
Knuckles said:My mod moved the 300 ohm over and I added (3) - 1W 100 ohm resistors.
NOPE! These are too wimpy.Microbatman said:Can I use these from Radio Shack?
http://www.radioshack.com/sm-100-ohm-1w-5-metal-oxide-film-resistor2-pack--pi-2062295.html
Pretty inexpensive mod.
wasp said:what about us canadians...
Knuckles said:wasp said:what about us canadians...
Shipping costs more from NY more like $25 and no tracking from USPS.
I am hoping ZapPat take care of Canadian Sales and Support for Infineon.
Johnbear said:Is the wire color coding on the infineon controller the same as the older ecrazyman controller?
RLT said:Hey Knuckles:
Any news on the 80A controller? I just ordered a 5305, so I'm going to need another controller soon, and would like to be able to go higher than 45A.
(P.S. I just finished hooking up the Infineon you shipped last week, to my loose 408. Seems to be working fine, first try, although I'm surprised that the 408 is significantly noisier than my brushed hub motors.)
hiaaannndddyyy said:I have just received my Infineon sensoless controller 48volt 30amp from keywin, but having a problem getting it to run smoothly have tried the three hull wirers, Green, Yellow, Blue, in the six possible combinations but cant get the motor(350watt brushless Ezee sprint) to run smoothly,
If I swop two of the three wires green, orange, and yellow in the bottom picture around would that make any difference?
Or any other suggestions much appreciated.
What a great guy we spent 30 minutes or so on the phone going over a few tests to try and pinpoint the problem and has now offered to take the SL controller and have a look at it, as he has the necessary expertise and diagnostic tools to hopefully pinpoint any problems, and will also do any modifications I what, this forum and its members are fantastic.geoff57 said:hi
we have to address the motor and the controller separetly to see which is at fault.
hi allaaannndddyyy said:Motor controller incompatibility Problems.
OK the controller is back after having some tests on a puma motor, which went well.
I have now got 2 new Ezee motors
which have been tested on a working controller and ran as expected;
This is the result of the Infineon 48v, 30a, SL Controller with the new motor
At low revs it works fine after around 17mph there seem to be a frequency/timing problem.
It’s almost identical to the problem I was having with original Ecrazyman controller before upgrading the 16 MHz with a 27 MHz resonator.
....This is the result of the Infineon 48v, 30a, SL Controller with the new motor
http://uk.youtube.com/watch?v=N734LrxZ49A
