starlightkayak
For anyone interested, we successfully installed the Kelly KEB controller in my Motorino XPn.
Couple of things we discovered:
Pros:
+ Amazing smoothness of ride and glide-like accel/decel - unreal - still playing with the programmable settings to see where I like it best.
+ The 60A continuous rating for the controller is pretty exact, according to the CA, and torque while riding blows me away, zero speed loss on hills that used to cut my speed by 1/3.
+ You can actually program it without removing it from the bike as long as the motor isn't "running". And you can leave the serial RS232 connected for easy access, as long as you waterproof the connections and keep the USB port covered when not in use.
Cons:
+ Low speed growl at throttle-on from a stop(0-2mph), and even after enabling the firmware's (#7) noise reduction, it's still noticeable. Even while braking, when we get to that 0-2mph zone, it growls (regen is on so that's likely why). Did some reading and apparently this is common in the Kellys. Didn't know that. amberwolf suggested it's probably to do with the current limiting being done by the Kelly on the motor. Will advise as I learn more.
+ Controller is large and needed some custom fitting, also the J2 cable came with only wires and no connectors, so we had to make our own from the old controller's old ones. Not a huge deal, but worth mentioning.
Neutral Comments:
+ Motor wires and power/grnd need ring-clamp terminals to attach to the controller with bolts (not provided)
+ Controller's #4 pin/wire (Thermistor) is actually the pin required for High Level Braking (which Motorinos use), so that wire is necessary for the brakes and can't be used for therm.
+ Sabrent's RS232 cables are way cheaper than the ones Kelly sells and work just fine - get one at Tiger Direct
+ You can program the controller prior to install using any 12V DC supply if you want, does not have to be 18-24 as the manual states
Hope this helps anyone looking to play around with Motorino and Kelly! Note, I am not the tech here, I am a digital developer so I work with software mostly, and leave the hardware to the experts. I can build my own PC, however I've never built a moto so I paid a mechanic to do my upgrades - having said that, I love to learn and asked a lot of questions while we were figuring it out.
OP: http://endless-sphere.com/forums/viewtopic.php?f=2&t=62617
Pros:
Cons:
Neutral Comments:
