blueb0ttle2
I am planning on installing the above-mentioned features (along with a head and tail light) on my 36 volt bike, since it is often used as if it were a moped in a 20mph zone of my hometown, and I thought it would be a good idea for safety and convenience. I am going to use Lyen's handy DC-DC converter (or two: its only 15W), to convert 36 to 24 volts, since I have a mountain of 24 V lights from McDesign
The turn signals are straightforward enough, with a handlebar switch cluster (also from McDesign) and a 24 volt blinker relay from electricscooterparts.com. The brake light though, may require some ingenuity...
Naturally it will be operated by with a relay and the brake switches. But what sort of voltages normally go through a brake switch? The full 36 volts? 5 V from the throttle? I need to find out. I don't want to open the controller, it has a lot of features that a normal brushed controller doesn't have and I don't want to risk breaking it unless absolutely necessary.
Cheers
Cheers
