Arlo1 said:Got a bit of a video up, check sig! :lol:
Thanks man/guys. I have alot more footage but the helmet cam I put on my helmet would not focus where I wanted so most of the video from it is useless.liveforphysics said:Arlo1 said:Got a bit of a video up, check sig! :lol:
Outstanding video Arlo! LOL! Top notch stuff!Burnouts till the tires blow always will have a special place in my heart.
Its funny you say that Luke because after I had it spining for a while I remember pulling back on the handdle bars slightly for more smoke! I never was trying to push forward to lighten the rear wheel I was trying to hold the front wheel down to prevent it from launching out from under me and causing damage to my balls or my friends truck in front of me.liveforphysics said:The part in the vid where you go to burn out, but the tire hooks solid, and you've got a bizzilion amps on tap at the battery, and the controller just takes it and no magic smoke escapes. That is a damn strong controller. You're doing your best to try to make something break, but you went with invincible LiPo, a Methy controller, and an X5. Damn good choices in parts to make something able to handle loads of abuse.Great build, and great video Arlo!
liveforphysics said:.....You're doing your best to try to make something break, but you went with invincible LiPo, a Methy controller, and an X5. ...
Why did you do that? Man I sure am happy you did though.methods said:All I did was sell him the parts at an incredible loss![]()
-methods
Arlo1 said:Why did you do that? Man I sure am happy you did though.methods said:All I did was sell him the parts at an incredible loss![]()
-methods![]()
As for credit lets just pass that to luck! I don't think you will want to see how hacked the inside of my bord is now. Next one wiil be nicer I promiss. Just need to quit blowing fets. And as long as I don't take it apart again it may be ok. Last time I took it apart I needed to test settings so I powered it up without a cover on it and BAM lightling flashed through the house. My GF was on the phone with her dad and she said she is pretty sure there isn't suposed to be lightning in the house! Once I could see again I saw the conectors we about done. I figure that was all because of a tiny little peice of metal or something in between the traces, good news is it doesnt exsist anymore. So how many volts/amps does it take to be leathal? 8)
Cool stuff I find my self wondering what the other 5 reasons are?bigmoose said:It is on my list of the 6 reasons why I should still not be walking the earth... :wink:
bigmoose said:Your skins's contact resistance is key, as is the path thru the heart as Luke mentioned. Left hand thru right foot and you end up in a wooden box.
steveo said:Hey Everyone,
I have a 18 fet infineon, which i'm servicing for a member.. i have a few questions ..
If i install a .2500mohms shunt in the controller .. do i just set the cycle analyst in the high range .. set my rshunt to .2500mohms .. and i'm good?? ... will the cycle anlayst display accurate readings?
steveo said:the problem ..
I was putting this controller on my bike for testing the shunt with the resistor for the .2500mohm shunt installed .. however i wasn't able to test anything .. i found something really strange..
The throttle line is all messed up!!..
it reads ... 0v 5v on the red wire & 5v on the yellow? bassically i have no throttle!
Anyone know why this is happening?
-steveo
Knuckles said:SAM-Pilot said:@ Steveo and Mike1
For regen at a higher voltage then 75 you need to make the LVC mod on R12. I have lowered R12 from 1.2K to 960R. This means the real voltage is the programmed voltage +25%. So 75V max regen voltage is now 94V.
See the last lines on my post and the right upper corner of the schematic: http://endless-sphere.com/forums/viewtopic.php?f=2&t=10312&start=315#p169765
The standard R12 value is 1200 ohm. Lowering the R12 value will increase the (programmed) regen voltage limit and also increase the (programmed) LVC.
EXAMPLE:
SAM-Pilot changed R12 to 960 ohm.
So if the regen voltage was programmed to 75V it is now actually 75 x (1200/960) = 93.75 V
AND if the LVC was programmed to 21V it is now actually 21 x (1200/960) = 26.25 V
